bhivetravels's avatar
bhivetravels
Front Shocks Replacement Question
8.1L 496, Chevy V8,
P32 Workhorse  W24 -- 24,000 GVRW
I noticed some popping -- loud popping when hitting any type pothole/bump -- in the right front coming from the wheel well and I believe my shocks are bad.
The Workhorse part number for the front shocks on my coach is W0006254 at $100 each. While I've replaced auto shocks before I've never replaced ones in a coach. Anything special I need to know or do?
  • I have 2005 southwind 22000 lbs chassis with bilsteins I have 70000 miles and no problem with shocks. How many miles due you have on your coach . Bilsteins are good for life. I would check out the front end before replacing shocks. Check the bushings both top and bottom. good luck
