tarnold's avatar
tarnold
Front sway bar "slop"
On an e350, the front stabilizer ends fit into rubber bushings within the I beam. How much flop if any should there be when you crawl under and push up and down where the ends go in the bushings? I've already added a Hellwig to the rear because there wasn't one(best improvement yet!)and was wondering about doing the front. I have about 3/16" travel now. Replacing the bushings would be a lot cheaper, but the Hellwig and Roadmaster use a much different way to attach these ends. Just don't know if their approach makes any improvement.
