opnspaces
Mar 31, 2020Navigator III
Radial pull can occur but it's not very common. If it was a radial pull it should have changed to the other direction when they swapped the two front tires side to side. You said you put new tires on. Did you notice the pull between the tire shop and the alignment shop?
