mexicanpiloto13's avatar
mexicanpiloto13
Explorer III
Apr 01, 2020
Front Tire alignment failure
I just got some new RV tires for our Monaco Dynasty, Goodyear G670s I think they are, and had them aligned by Purcells's Tire Truck place in Phoenix. The alignment wasn't that bad when I went in, but when leaving, the rig was pulling sharply to the right. I called them and they suspected I had "radial pull" since the alignment was right on.
They said to come back and they would switch the front tires and see if that wasn't better. It wasn't much. The rig still pulled to the right. I know some roads have a crown on them for drainage, but even long stretches of flat freeway, it would produce the movement to the right. They said come back in and we'll check the alignment, which I did. (80 mile drive from our home).
They found the alignment was off and redid the entire job, still pulling to the right when I left. They were now talking of swapping the rear duals to the front and I gave up. I told them nothing seems to be working. Last time Spectrac did it, in Mesa, and did a super job. Is radial pull that big an issue or could their calibrations be off? Thanks for your thoughts!!
