gsf35099
Aug 21, 2017Explorer
jschmelzer wrote:
The level in the coach indicated that we were level after the auto-jacks finished. The front left wheel was about 2-3" off the ground and the front right wheel was about 4-6" off the ground.
Unfortunately, the best or flat part of the 40' pad was blocked by a tree limb that was the same height as the A/C unit.
The manual jack instructions imply that I can lower the jacks front, back, left or right. See no instructions for manually retracting (raising) one set of jacks. The 'retract' button says 'all jacks'.
I guess I have to be prepared to move sites if I cannot get the front tires lowered onto the blocks. Could be a major problem if CG is full.
What leveling system do you have?
If it's Power Gear, retract the jacks, turn the system off then back on, then hold down the manual button until the LED is on (usually 3-5 sec). From here you can extend them as you like using the touch pad. I've never found how to retract only one.
