Executive45
Feb 21, 2016Explorer III
Bungee cord or thumb tacks until you fix it.
You'll need a test light to see if you're getting power to it assuming it's powered. If you are, then the motor is most likely bad. Easy fix but the shade has to be removed. Still no biggie. If no power, assuming the other side works, then look for a bad ground. If no power on either side, check for a blown fuse....Dennis
