campingman55's avatar
campingman55
front window shade
ok i havw a 2005 vectra and it has a powerd front window shade and it will go down but will not go up and there is a sunshade that works both ways and i need to get it up al so my jack will not work and there is no link light on at the touch panel i hope some body can help me and iu can send a private message if u want to
  • well we got it fixed today when i turned off the coach batterys it wiped out the stops so all we did was reprogam it and works like a dream now only if i could fix my jack pribelm
  • Call MCD tech support
    800-804-1757 or 972-548-1850 Their tech support is good.
    You can also go on line and check out their support documentation. Could be one of the stop switches if the battery was low and lost its memory.
  • i dont know where they are i have checked all the fuses where i can find them as i said it goes down but not up
