- charlysmom_dadExplorerWe had to reprogram our windshield shade when it wouldn't go up.
There's a youtube video for it.
https://youtu.be/ZAsryA0z6dc - rgatijnet1Explorer IIIBefore I replaced the switches, our electric shades would stop. Try playing with the switch to see if it will retract enough for you to drive.
- Executive45Explorer IIIBungee cord or thumb tacks until you fix it.
You'll need a test light to see if you're getting power to it assuming it's powered. If you are, then the motor is most likely bad. Easy fix but the shade has to be removed. Still no biggie. If no power, assuming the other side works, then look for a bad ground. If no power on either side, check for a blown fuse....Dennis
38,778 PostsLatest Activity: Jun 06, 2026
