wallynm
Sep 22, 2018Explorer
Read this thread to understand correct description to use. it ain't frozen as it is not below 32
mexicanpiloto13 wrote:
We went to light the pilot light today on a standard Atwood Wedgewood RV oven and had a strange thing happen. As you may know, you turn the oven knob to "light pilot light" and depress it while you light the pilot, then after holding it for a short period, turn counterclockwise to the temperature and the oven lights. This time, the pilot light lit, and the knob was frozen. We couldn't turn the oven on, we couldn't turn it off, the pilot light was burning and we couldn't get it off. We finally shut off all propane at the tank and it went out. Its still frozen in the "light pilot light" position. I sprayed a little silicon on the knob when it had cooled (don't know whether I should have done that, but it made no difference)
One thing that could be a factor. My wife was baking something and the oven was very hot. She turned the oven off, and then decided to relight the oven to further cook the item. That's when we attempted to light the pilot light again and the switch jammed. We think that may have had something to do with the malfunction. All the burners on top work and the pilot lit normally so I think the thermostat and regulators are ok. Seems the switch is shot now. Any thoughts? (other than use the microwave?) I remember years ago, our door lock on an RV wouldn't work when it got hot as the tumblers expanded, and later it the day, the key would work.
