rgatijnet1
Feb 12, 2016Explorer III
Keep in mind that the larger the holes to allow air in to the wet bay, the more cold air you are allowing to get up in to your coach. A lot of people just put a 100 watt incandescent light bulb in the wet bay that is controlled by a thermostat to come on when temps get low enough. This has worked on our coach at 5 below zero and may work lower.
