DrewE
Apr 10, 2016Explorer III
The Vista is a gas coach. The only way the gasoline would generally be used for heating on such a motorhome is by running the generator to power an electric heater.
In general, I would expect three month old gasoline to be okay to use, though it's better not to let it sit. I would just drive off. In the future, when it will be parked for an extended time, the best action is to put an appropriate dosage of fuel stabilizer in and fill the tank all the way up, and then drive for a bit and run the generator for a bit (so that the treated gas gets through the gas lines and whole fuel system). You want to have the tank as nearly full as practical because that means there's less air space for moist air and so less condensation to put water in the gas.
Propane needs no special preparation for storage, and does not go bad or wear out or break down.
38,778 PostsLatest Activity: Jun 10, 2026
