Tom_BarbExplorer IIOct 12, 2017Fuel capsWe were required to replace our 150 gallon fuel tank due to a crack resulting from the tank flexing as the pressure in the tank varying, as the fuel is used the space of that fuel must be replaced by ...Show More
K_CharlesExplorerOct 13, 2017The vented cap should only be 2 PSI and 2" of vacuum.The non vented cap is the one you don't want.You can still buy them both.
Related ContentNo fuel cap?Turnbuckle blocks gas capDiesel Fuel CapFuel Cap ReplacementRam Cummins locking fuel cap
