ScottG
Feb 28, 2018Nomad
Do the cycling of the key about 10 to 12 times. Makes all the difference for me.
Listen for the fuel pump running. cycle the key after it stops - if it stops. There was a s/w update to some Cummins platforms that causes the pump to continue running rather than stop. If it continues to run, you can hear it change pitch once the filters are full.
38,768 PostsLatest Activity: Nov 21, 2015
