wtmtnhikerExplorerFeb 28, 2018Fuel Filters change ISC CumminsMy 2005 Cummins ISC has 2 fuel filters. One has the water sensor and drain which Cummins manual says is the suction filter and the other is the pressure filter. I changed both filters but according to...Show More
AikenRacerExplorerMar 01, 2018I fill both filters and then go through the priming process...no problems.
Related ContentRAM Cummins fuel filter change intervalCummins 5.9 FiltersK & N filter changeBelt change 300hp cumminsAir filter change on Cummins ISL
