wtmtnhiker
Feb 18, 2018Explorer
Fuel filters
Hi all, I have a 2005 Cummins 330 ISC and will be changing out the fuel filters soon. Do I need to pre fill them or just cycle the ign switch a few times? I have read conflicting info on this and j...
wtmtnhiker wrote:ScottG wrote:
With an 05, you can turn the ign switch on and listen for the pump. I like to do this 5 or 6 times. The common rail system will purge the air out.
No need to pre-fill.
DO NOT put ATF in a CR system.
I believe after reading comments here and doing more research that ScottG is correct. This is the procedure I will use.
Sounds like using ATF is an old school technique that still gets used at times today needed or not. Thanks to all who replied.
