billseal
Oct 25, 2013Explorer
Fuel Gauge
My fuel gauge is malfunctioning. Sometimes it displays correctly but will move to a full tank when I know it is half full. Will appreciate any suggestion to fix this.
kdk wrote:
My sending unit on my 06 Ambassador went bad and I got one directly from Centroid. I accessed the sender by removing 2 screws from the bottom of the fuel door panel and swinging it up. The sender is located on the top drivers side of the fuel tank. Held in with 5 screws if my memory is correct and then lifted out the top of the tank. Be sure to label where the 3 wires are connected before removing them. This is not a difficult project. I think the sender was about $70.
Blessings kdk
donnie d wrote:
I have a 2000 Diplomat and sending unit went out also. It is located on side of tank. It is accessible thru a white screw plate in rear of first compartment on passenger side. It is supposed to be a 100 gal tank but when measured it is a 110 gal. call centroid with meas. and they can replace. You will have to empty tank because it is located on bottom side. It is a diy project.
http://www.centroidproducts.com/moncal.htm
DUNEBUGGYDOUG wrote:
The sending unit is in the fuel tank
BillofPA wrote:
I had the same problems as you guys. (See signature) I had the sending unit in the fuel tank replaced and now all is well.
