Hi,
When I had to drop my tank, I purchased one of these
500 lb. Capacity Table Carts to put under the tank for support. In my opinion, it was money well spent. For the gas tank, I didn't install the push handle as shown, so it would fit under the moho.
The gas tank is heavy and awkward to handle and you can't get all of the gas out of it, so once it starts tipping, it's tough to get back into position. The cart above allowed me to loosen everything up and gently lower the tank. It was always completely under control.
As a bonus, this cart also came in handy about a year later when we had to replace the refrigerator in the rig. I wheeled the cart into the hallway and slid the old refer right onto the cart. It was great to be able to adjust the height exactly as needed, and then wheel it out to the living room and out the door. We installed the new refer the same way.
Now, mostly I just use it as an adjustable height work table around the garage.
By the way, when I had my tank out, I had a friend weld an extension onto the generator pick-up tube so now it's about an inch off the bottom of the tank, instead of about 4". I figure now it'll run the tank down until below 10 gallons. Previously, the generator would kick out with about 20-25 gallons still in the tank. This bothered me during an extended power outage at home: Knowing there was over 20 gallons of gas in the tank that the generator couldn't use, so I had to dump a couple of 5 gallon jugs in. Not a big deal, but it still bothered me. Plus, now when running down the road, the generator will keep running well past the 400 mile mark on a tank of gas. Previously, the generator might start kicking off about 350 miles. This gives me a bit more flexibility when planning fuel stops.
Good Luck,
~Rick
