OK, My problem is :: I have a 2011 Four Winds Hurricane, but the problem is I'm having a problem with the fuel line to the genitor, on last trip It was hot and we wanted to run the roof air along ...
Of course you could also have a bad/weak fuel pump. You sprayed fuel in to the carb and it ran. This bypasses the fuel pump. On a 2011 model I would be more suspect of a bad/weak fuel pump than a bad fuel line. Sucking fuel from a near by can is not the same as sucking fuel from your main tank. Just saying......
