Michael1222's avatar
Michael1222
fuel line issues
Own 2003 Four Winds 5000 28a. Went camping last month. Pulled into lot to use swimming pool. When exiting the rig, I noticed gas coming out all over. Used the ever famous duck tape and drove to an rv mechanic. He said the fuel line blew, had part, fixed it and away we went. Said it is very likely that a squirrel, or some rodent ate through the line. Two days ago, went to where we have rv stored, with intention of taking to my rv mechanic to seal leak in window which he did 3 months ago. While traveling there, same thing happened. Gas was everywhere. However, I was able to drive to the rv place because it was so close to where we store the rv. He is now replacing the fuel line part above the gas tank. Question. Is it possible that a squirrel or rodent could be doing that? I have been putting mothballs under the rig which was suggested to me. Why don't they provide copper or some kind of metal for the fuel line if a rodent is causing that problem. I will state that we purchased this 2003 one year ago, and could it be possible that the fuel line was on the border of blowing?
Any suggestions or comments would be greatly appreciated. We love our Class C and already are booked to go next week and camp at a state park for 10 days.
Michael
  • Unsure about Chevy chassis, but the Ford chassis of that vintage is a solid line, or braided steel where flex is needed. Highly doubtful a rodent would be gnawing through those.
    What likely happened is the first line failed for whatever reason and the mechanic installed a rubber line as a replacement. Those just do not last.
  • I usually tow a car and get about 9 mpg. When I don't tow it is closer to 10 mpg, but I haven't done enough mileage without the toad to really know.
  • Curious!! What kind of mileage do you get with your Class C. We get about 10 miles.
  • Michael1222 wrote:
    Chevy Chassis
    Thanks. I guess I should have a look at my gas line.
  • Other than mothballs thrown under rv when stored, is there an animal repellant that can be sprayed on the gas lines, etc?
  • Just wondering if your 28A is on a Ford or Chevy chassis.
    ....Why don't they provide copper or some kind of metal for the fuel line if a rodent is causing that problem. ...
    Because rubber/neoprene fuel line is cheaper, and will normally last beyond the warranty period.
  • If you get fuel lines replaced, if at all possible, get the steel braided ones. That way, they won't be chewed through should a rodent want a nice little meal.
  • Ask to see the part that is being replaced. It may be obvious if a rodent chewed it or was some other type of failure.
