n9egm
Jul 17, 2015Explorer
fuel line
OK, My problem is :: I have a 2011 Four Winds Hurricane, but the problem is I'm having a problem with the fuel line to the genitor, on last trip It was hot and we wanted to run the roof air along ...
RLS7201 wrote:rgatijnet1 wrote:
Of course you could also have a bad/weak fuel pump. You sprayed fuel in to the carb and it ran. This bypasses the fuel pump. On a 2011 model I would be more suspect of a bad/weak fuel pump than a bad fuel line. Sucking fuel from a near by can is not the same as sucking fuel from your main tank. Just saying......
Exactly correct.
The fuel pump will be working harder lifting fuel from the can on the ground than when it's pulling fuel from a higher frame mounted tank.
Richard
