OK, My problem is :: I have a 2011 Four Winds Hurricane, but the problem is I'm having a problem with the fuel line to the genitor, on last trip It was hot and we wanted to run the roof air along ...
If it is the fuel line from the tank when you replace it go with fuel injector rubber hose it will last longer. When I replaced my line I just used short pieces of hose at connection points and the rest I used solid line copper or steel
