CaptR
Aug 19, 2018Explorer
Thank you moderator for moving this into the correct forum and thank you Old Timer for the insiteful response- 3x 10 sec... pumping the gas pedal as well it usually starts right up. Is the fix something I’ll need to take into the shop or shady tree with limited tools and resources?
Any insight for these Fourseasons Majestic your 2000 issues:
Lose fresh water through pressure hose fill bib when running or hose is off, overdrive seamlessly stops working @ every 15 min for a couple minutes and seamlessly starts working again only when high outdoor temps (my guess the torque converter over heats and has some sort of shut-off and turns back on when temp goes down?), cruise control not working- an easy fix to look for like a fuse? Lastly, the roof vents need work- didn’t find a name on them- need new cranking mechanism, cracked frame, etc... roof vent name and model? Where to find parts? Lastly, is there an inverter I haven’t found yet to run the 110 outlets off the house batteries (this coach appears to be completely stock except maybe the cassette stereo which sounds way too good to be in a former rental)?
Been living and putting mileage on it... lucked out, got a great vehicle for the $.
Thanks again for the helpful input! Rex
