swat455 wrote:
hey turbo maybe the foam is glued the tank to bottom of rv ? 2nd the sender unit I think your talking about will be in the tank were the fuel lines go in .. the filler tube should have A rubber coupling to separate it.....also those fuel line hoses don't use rubber spend the extra $ get the Teflon lined hose as the ethanol mix in gas will make rubber lines inc evap leak vapor gas /source car craft , hot rod, and hemmings hope that helps
Thanks for the info. I'll check out those hoses.
The foam may have it glued in. I can see a crack in the foam along the right frame rail where the tank has moved very slightly.
The filler tube does have a rubber coupling, but it's clamped on the inside of the frame rail. The hole I cut in the floor allowed me to get that clamp off.
I'll have to goof around with it some more today.
