MrWizard wrote:
100gal tank
pump in 85gal, that means you still had fuel in the tank when you stopped right
you didn't run it empty, so you can't pump 100gal in to it
why are you trying to fill up the fill tube
when it stops filling normal its full
once the vent tube is blocked air can't escape, so trying to fill anymore is going to make it foam
Yes, I was just under half full when I stopped to fill up. At half a tank, I should have about 50 gallons but after putting in 29 gallons, it clicked off. Then I milked it, tried taking the other cap off, and put the jacks down to raise the fueling side just to put another 12 gallons. That 12 gallons took about 20 minutes. When I left the station the needle still showed below the "F". I'm guessing I got about 90-92 gallons in but I have no idea. I guess I don't care that much about getting an extra few miles down the road but I was trying to figure MPG and couldn't get it full to give me a good starting point!
