Mr_Mark1
Jun 26, 2016Explorer
We had friends that had a full wall slide in a Monaco Signature, they never had a problem with it.
A full wall slide really opens up the space. I prefer four separate slides as we have been in a few situations where an obstacle would inhibit the full wall side going out. We've had a tree, a bush, a utility pole blocking the center area of the coach.
If you don't like ducking under the full wall slide for your water bay connections, you have to plan your connections accordingly (connect before deploying the FWS and disconnect afterwards).
Everything can be worked around. Buy and drive what you like. We did.
Safe travels,
MM.
Safe travels,
MM.
38,780 PostsLatest Activity: Aug 05, 2026
