- afrescopXxExplorerInsurance company is under no obligation to pay a claim if they find out you are towing over manufacturer limits.
- jerseyjimExplorerMy gasser (V-10) has a 5000 pound limit. I currently tow a Ford Ranger 4WD/automatic. Had to buy a "Ford only" "transfer case disconnect kit. Truck tows fine..BUT is 4000 pounds.
Does , say, Blue-Ox make a baseplate for your Chevy truck? Better find out....hit their website.
I'm going to guess that your 1500, like the F-150 is way over 5000 pounds. You can tow it, you will most likely be swapping out transmissions, premature engine problems and maybe even chassis problems. I just don't know. However, what I DO know, is that you can solve this problem by buying a diesel pusher. Then you can tow just about anything.
Whatever you decide, g'luck ! - tatestExplorer IIA motorhome on the F-53 chassis might have a towing capacity as high as 10,000 pounds or as little as 4,000 pounds. It depends on the size of the motorhome, as smaller ones leave more of a basic 26,000 GCWR available for towing.
- TrackrigExplorer IIHere's a friend towing his 3/4T Diesel behind his MH. It can be done if you have the horse power / torque and a strong hitch. His truck is a 4X4 with a transfer case that when shifted into neutral, makes the truck towable. He used to tow an Excursion but got fed up with the driveline disconnect.
Bill - sehunterExplorerBrandon, My W24 chasis has 6K towing capacity.
- fyrflieExplorer III
RVMike wrote:
Also an automatic cannot be towed four down.
That's only partially correct. There is a company called Remco Industries that produces equipment that allows towing of an automatic equipped vehicle?
http://www.remcoindustries.com
As mentioned, the weight of your toad will be the determining factor. - RVMikeExplorerIt's the weight of the truck that is a restriction, most gas motorhomes have a 5k limit. Also an automatic cannot be towed four down. That's why I bought a Frontier with a manual trans. It weights in at4200 lbs and my 2015 v10 has no problems.
38,766 PostsLatest Activity: Jan 10, 2026
