ForestRiverTeac's avatar
Jul 10, 2015
Funky EMS Issues
When we purchased our new Thor A.C.E. we had a Progressive Industries EMS unit installed. We'd had a portable one with our last rig, and firmly believe in their ability to save rigs needless damage by shutting them down when the power coming into the rig isn't sufficient to run things, and acting as a sacrificial lamb when there's a power spike. But our current issue has got us scratching our heads.
We're camped at a KOA that is not full. It's not hot. We're not running our AC. But we are running our fridge and hot water tank on shore power instead of propane. When we plug in our coffee pot the EMS shuts down everything else that is running on shore power, and the reading on our EMS shows that we've had a low power event.
Talking with the KOA guys isn't really helpful. They admit that they have no clue about anything electrical. And Progressive has said that their unit is doing what it's supposed to.
Our rig is wired for 30amp. Does that play into this at all? Is it simply an issue of not enough power coming into the rig when we're using the items I've listed above? I don't like having to use propane if it's something that we can address with the rig, but will live with it if it's a campground issue (which I can't do anything about).
I hope I've explained this sufficiently. Thanks for your feedback.
    When we purchased our coach used, along with it's factory EMS, it was a real PITA with the way it was set up for shedding loads and making it difficult for doing anything.
    Evidently previous two owners lived with it, but it wasn't long before I dug into it with some changes, so that the ac's are the only things that will shed. If for some reason it still loads up after that and although, I've never seen it happen, then we'll just have to rely on the circuit breakers for doing their job.
    In addition, I've split the rear ac circuit and sometimes run it on the campground pedestal separately, reserving a full 30amps for the rest of the coach. This is one of my best mods to date and works well, so at a loss, as to why the manufacture didn't do this on 30amp coaches in the first place.
  • its sounds as your pushing the limits and it did its job. If it runs fine with lesser load you figured it out. I have had this happen in the past too.
  • I am wired for 50 amps. When I run my fridge, water heater, A/C, and coffee pot I run 35 to 40 amps. Especially if one has just turned on. I think the problem is drawing over 30 amps. The EMS is doing its job. It shuts down before fuses blow. That said, my ems does power management. If I draw over 50 amps the ems will shut off certain items based on priority. Don't know if your system is set up to do that.
    You can figure out this fairly quickly with a little math:
    Coffee pot = 10 - 15 amps
    Electric hot water heater = 10 - 15 amps
    Electric refrigerator heating element = 10 - 15 amps
    miscellaneous other loads = unknown but likely another 5 amps
    Total draw = 35 AMPs
    Note most breakers won't trip immediately for slight overloads. The likely thing that is happening is you are getting a voltage sag which actually increases the current draw of resistive appliances such as coffee makers, heaters and such. I have stayed at KOA camps where the wiring was undersized and the voltage was already low to begin with. I had an Autoformer to boost the voltage to alleviate this particular problem. The formula to figure out how much current you are drawing is quite easy: P=IE or put another more useful way watts = amps x volts. You can use a bit of algebra to figure out how to find the amp draw or wattage if given the other numbers. Note that the lower the voltage is the higher the amperage required to perform the same amount of work or wattage. This means an autoformer is very useful because it will boost the voltage. So if you have a park that only is supplying 109 volts at the pedestal it will boost the voltage to 119 volts allowing your appliances to do the work while drawing less current. Better yet they don't get damaged by a low voltage. This setup complements your EMS system in protecting your rig. If you want to get the actual current draw of each of your appliances there are inexpensive watt hour meters that you can plug the appliance into and then watch the meter to see the actual watts and current drawn by the appliance at a given time. That way you know exactly what can or cannot be used at the same time.
    Thanks for your post! I'm going to have to re-read it several times to understand it. ;)
    But for now, where does one find an autoformer, and how much do they cost?
    An autoformer for a 30 AMP rig costs are as follows:
    Amazon:
    Hughes autoformer model # RV2130 $388.88
    Surge Guard model #10176 $382.72
    Camping World:
    Hughes autoformer model # RV2130$369.99
    Surge Guard model #10176 $410.45
    You may be able to find less expensive prices online as well. I have owned both.
  • Our previoius rig was 50 amp, so we're learning new & different ways to deal with things in this one. I think an easy fix will be to fire up the hot water tank with LP when we get up, then shut it down. And when we need to use the AC, we'll run the fridge on propane. Hopefully that'll take care of things.
    We're grateful that no fuses have been blown, and that the EMS is doing its job.
  • Have you looked at the current(amps) draw on your EMS meter before you plug in your coffee pot? on 30 amp service you do have limitations. Your coffee pot could be trying to use as much as your AC unit.
    Your water heater may also be using 120 volts AC and your inverter/charger may also be trying to draw more current than is available.
    When hooked up to 30 amp service, you are going to have to compromise when you use certain high current items.
  • I would think that if over loaded, a breaker would trip. I would check the voltage at the pedestal while operating. I trust the ems far more than a campground wiring system.
