Ivylog
Apr 04, 2015Explorer III
You may not have a inverter/charger... just a 12V converter which is usually in the Bedroom. If you have a panel with a bunch of 12V spaded fuses that hums... it's not charging your batteries. If none of the above suggestions work, I'd go buy a $40 battery charger for now.
If you do not have a inverter/charge I'd probably get one and not fix the cheap converter that's usually a single stage boil the water out of your batteries charger.
38,769 PostsLatest Activity: Apr 04, 2026
