Wagsrb's avatar
Wagsrb
Furnace access
How do I gain access to the furnace on a 2010 Winnebago, Sightseer it in the rear of the camper ?
  • If you only have intake/exhaust plates on outside then you have to access from inside the RV. Remove front grill. Then pull furnace
    If you have an access panel on outside of RV.remove the panel screws to access furnace
    ON EDIT:
    From the outside.....license plate is mounted on furnace access panel
