Old-Biscuit
Jan 20, 2014Explorer III
Ignitor lock-out.
After 3 attempts to lite off it will go to lock-out.
Low gas pressure...should be 11" WC with at least 50% of other gas appliances in service
Blocked exhaust...creates an imbalance in air/fuel ratio
Spark electrode dirty/out of position......clean electrode with emery cloth/set spark gap to 1/8"
Spark electrode wire bad
Circuit board....bad connection/contacts on board (pull connector/clean contact surface with pencil eraser) OR the board is bad
Clean up the spark electrode and board contacts and check ground connections on furnace
38,768 PostsLatest Activity: Nov 21, 2015
