TXiceman wrote:
Your trailer should have a list of appliance and model numbers somewhere in the documents.  The owners manuals should also have a book on the furnace that provides the basic model.
As for the Pilot comment, the newer furnaces do not have a standing pilot.  They are DSI or Direct Spark Ignition.
The sequence of operation is for the fan to come on first and run fro about 30 seconds to clear any gas build up in the combustion chamber.  Once the sail switch is made or closed, the gas valve will open and the ignition sequence will start.  The ignitor will start to spark and you will hear a popping or clicking sound.  The burner should light and the thermocouple or flame detector will confirm a flame is present and the burner will continue to burn until the thermostat is satisfied and close the gas valve.  The fan will continue to run for a time until the combustion exchanger is cooled.
In the start sequence, if the burner does not ignite, the ignition circuit will shut down and after a period of time, will try igniting again.  If the burner does not ignite on the 3rd try, the furnace will lock out and you will have to manually shut off the furnace and reset it by turning off the thermostat.
The owners manual for the furnace should have a small trouble shooting guide and you can find more information online.
Ken
I'll dig out the manuals and go through them. I've been reading the Winnebago manual but haven't made it to any of the others yet. The previous owner kept everything so I've got them all.
When I turned it on a few minutes ago it started putting out some heat pretty quickly. Learned my lesson I guess.
