Kidoo
Aug 18, 2015Explorer
Problem solved. I went to a shop and he first replaced the propane valve. It did not fix the problem but he said that these valves get dirty over time and does not distribute proper amount of propane. Since the valve was as hold as the RV, he said he did not want to replace something that could fix the problem and me comming back a while after with another furnace problem. This guy is a propane expert and he is next to a big campers site. He showed me an open one and it was quite dirty. It was also time to clean my fridge, it was felty, so 2 in 1.
Then he replaced the circuit board and it fixed the problem. I had this circuit board tested by another RV place a couple weeks ago and it tested good. So even though the board tested good, there are good chances that it is not. functionning properly.
38,782 PostsLatest Activity: Sep 10, 2026
