enblethen wrote:
Check the multi-wire connector on the circuit board.
Do you smell any propane?
Get an electric heater!
Sail switch should be OK as power is getting to circuit board.
I tried to start it about a month ago, and thought I smelled a little propane then, but had no time to look at it until last Friday. Took the out side cover off and tried to start it several times. The blower will come on and the igniter will click for a couple seconds three times then it will shut down. Tried this several times with no luck or smell of propane. Hoping that maybe there is a valve that has never been opened. The dealer said they checked it during the PDI- who knows:h? We've only used the camper 3 times since we bought it-brand new.
