Artum_Snowbird
Dec 27, 2014Explorer
A good way to check is to hold a length of tissue near the vent, then have someone else block one of the near vents or more. You should see noticeable deflection with some vents blocked. If you play with the blocking you might be able to produce a better more even flow.
38,782 PostsLatest Activity: Aug 31, 2026
