Goldencrazy
Dec 28, 2014Explorer
MWJones wrote:
Was it doing this BEFORE you got your "newish" furnace installed or did the problem began afterwards? There is most likely a conection.
I didn't need it when I got it last spring. This winter it has never really performed to my expectation. I am getting heat through the ducks that run down the center of the coach as I feel it in the floor. Bedroom and bathroom heat as they are closest to furnace but all the heat seems to be gravity and not forced. A little heat rising out of registers but not forced through. I had to have a new circuit board installed in furnace when I began to use it this fall and furnace ran and worked ok. Couldn't really tell about vents as they were mostly covered by the slides. Another thing if I were not traveling the dealer would be dealing with.
38,782 PostsLatest Activity: Aug 31, 2026
