xtal_01
Nov 10, 2019Explorer
Furnace trouble again .....
I don't know what I did wrong this time ....
So back to the 1999 28-T Bounder.
I put a new furnace in last year ... second time I did this .. SUBURBAN FURNACE SF-35
I had also found the safety valve was full of oil (caused low flow and furnace not to run) ... fixed.
Tried the furnace a few weeks ago ... started but only after a few tries.
Well the only thing I had not replaced was the regulator.
So I was on here a couple weeks ago and was recommended to get this one: https://www.amazon.com/gp/product/B00KTS0QDY/ref=ppx_yo_dt_b_asin_image_o03_s00?ie=UTF8&psc=1
It came in and looks very close the the original ... fit great!
Tried the furnace .... started right up!
Only "odd" thing I noticed was the regulator "singing" ... noticeable buzzing sound. I don't remember my old one doing this.
The noise "could" also be the flow limiter right before the regulator .... part of a Tee kit I put in years ago so I could feed the RV with an external tank ... the piece that screws into the regulator has what I think is a high flow shut off (think they are called velocity fuses) ... in case a line breaks and there is high flow it shuts off the line.
Hard to tell but I think it is the regulator.
Anyway ..... furnace runs for about 5 minutes then I hear the noise stop from the regulator and the flame go out .... it is no were near temperature so it is not the thermostat ... but the fan keeps running.
Then after a couple minutes, the furnace ignites again! Fan has continued to run during this time.
Then after about 5 minutes (maybe less) .... flame goes out .....
Fan still running .... a couple minutes pass ... furnace ignites again!
It does this consistently over and over again!
So what is going on ???????????????????
My best "guess" is that the over temp switch is tripping
When it cools, the burner comes back on.
I checked the vents in the RV ... clear.
I checked inlet and exhaust for bugs (I have a screen on them) ... blew it out ... clear.
Could this be it ... if the switch trips, will the fan keep running and the furnace start again when it cools ??????
If this is the problem .... why?
Bad switch? Furnace is only a year old and this has never happened before.
Why did it show up when I changed out the regulator? More propane now so it is getting hotter?
Bad regulator giving too much pressure?
I am not sure what to do ... I need to get this fixed in a few weeks .....any suggestions????
Also, if it is the switch, which one is it ... I see a few different ones out there listed for a SF-35
Another "also", I did check the stove burner ... goes super low with no problem ... on high it seems to have a slight pulsation to the flame (just slightly ... high .. a bit lower ...high ... a bit lower) ... not much but something I noticed.
Thanks ..... Mike
Thanks ..... Mike
