The bedroom light fuse in our 2010 Tioga Ranger blows out immediately when I plug it in. This just started happening. Any ideas on the cause would be appreciated. Tom
That very clearly says short to ground. Pull the fixture and try a fuse again. If it blows, then disconnect the wire at the fuse box/block. Try another fuse. It should stay healthy and you will troubleshoot a short in the wire. If the fuse still blows with the wire removed, you have a bad fuse block.
