Rick_Jay
May 29, 2022Explorer II
hotjag1 wrote:
I found 4 inline connector fuses in that compartment, but they all looked good and they are not labeled as to what they are for.
hotjag1,
I know nothing about your specific chassis or motorhome, so I apologize if what I say may not be applicable, but I'm going to try to stay as general as possible.
When you state "...but they all looked good", what does "looked good" mean?
Did you actually test each fuse for continuity or just give a visual inspection? Fuses may "look good" but in fact test bad.
Also, make sure to clean up any electrical connection you investigate. It's possible on older rigs for corrosion or vibration to loosen connections enough so that they fail under load, even though visually they might appear to be good.
Someone had mentioned that it might be controlled by a relay, and if that's true, then you'll need to trace down and find the proper relay. Relays can either fail on the input (coil) side or the output (switch) side. If a relay is used, then there are probably at least two fuses involved. One for the input coil circuit (probably combined with other things) and another for the output compressor clutch circuit (probably 20A?). If you find that a relay IS used in the circuit (maybe Doug knows?) I can give you some additional hints about relay troubleshooting. Oftentimes, if there's an identical relay used elsewhere on the chassis, you can swap them to note if the problem corrects itself.
Again, while having nowhere near Doug's caliber of expertise, I believe his response to the statement from the service is on target on all points. It puzzles me that they would do ANYTHING if the compressor wouldn't run? It almost sounds like they had a test procedure they used and gave it to a tech who doesn't really understand how the system works. The tech just did what the procedure stated and noted the results. They didn't have any diagnostic experience to question anything that was done or discovered. For instance, if the system was, in fact, only 1 pound low in refrigerant the low-pressure system shouldn't have disabled it, so that would indicate something else is going on. And like Doug stated, if they DID jump the low-pressure switch, why not make note of that? And if their tests indicated no voltage appears at the compressor clutch, I would think they'd have the wire tracing equipment to locate where the problem is.
IF they wanted to.
I'll try to be kind and just say that you might have had a tech that was not well-versed in A/C systems. Or the shop didn't want to get too deep into this project.
Again, Good Luck,
~Rick
