hotjag1Explorer IIMay 27, 2022Fuse location on engine a/c compressorThe engine a/c compressor doesn't kick on when activating the dash a/c button. There is no power to the wire that is connected to the compressor. I'm guessing that there is a blown fuse as it has work...Show More
Bird_FreakExplorer IIMay 29, 2022Have you checked the low pressure switch itself to see if you are getting power to it? If you haven't it may just be a bad switch.
Related ContentFuse panel locateFCFS Site locationsAc engine compressorPotential engine overheatingNear engine overheating gauge
