j-d
Sep 21, 2017Explorer II
OH, There's a two-wire connector that powers only the Motor. Hard to see upside down in the dark in a black corner of the steps base. But it'd be possible to rig a Test Light, pull that plug to the Motor and connect the Light.
And... rig a connector to a long test wire to try running the MOTOR and be away from the mechanism doing it.
WARNING!!! Kwikee Control Module backs the power off the Motor when the step stops "hard" in either direction. Test Wire does NOT, and the Motor will burn out if the Test Power is left connected!
