dougrainer
Feb 21, 2016Nomad
The Genset 12 volt fuse (at the Genset and is an Onan fuse) is the only fuse for the remote switches. If BOTH quit, go to the remote wire quick connect at the Genset and check for corroded pins or a bad connection. Also, Start the Genset and then see if the Remote switches either light up or will STOP the Genset. If so, the quick connect at the Genset is the problem. Also, it is a GROUND connection that starts and stops the Genset, so the fuse will not usually cause the Genset to not start. Doug
