dougrainer
Mar 03, 2016Nomad
bumpus4 wrote:
Doug, The coach switches will stop the gen. but the lights inside the switch do not light up when trying to start the gen. I did discover the coach switches will start the gen from inside the coach if I hold them to start for about 10 seconds. This started to happen after I unplugged and reconnected the quick disconnect at the gen.
At least I can start the from inside the coach now.
Thank you for your help.
bumpus4
Replace the quick connect. Look inside both plugs and you will see corroded or broken pins. Long shot would be where they spliced the 2 remote switch harness's to that remote harness from the Genset. usually that connection is within 2 or 3 feet of the quick connect. Doug
