rgatijnet1
Mar 01, 2016Explorer III
I think the bolt should be replaced, rather than welded. Perhaps they used a lower grade bolt instead of a high strength bolt. IN any case, the bolt was installed when the unit was built and there must be a way to replace the bolt now.
I remember watching one show on cable where they completely removed a slide on an RV, repaired it, and reinstalled the slide in about 5 hours.
As far as your extended warranty, who knows? Some specifically exclude problems with the slide. You need to read the fine print and contact them before any work is done.
38,780 PostsLatest Activity: Jul 04, 2015
