George_Beggs
Mar 02, 2016Explorer
You could tack a wire to the top side of the bolt ( like Blue Ox does to the nuts on their base plates). Then you just bend the wire so the bolt can be aligned with the hole and drop it in. Use red Locktite on the nut.
How do you plan to remove the broken bolt heads if they are welded in?
38,782 PostsLatest Activity: Aug 23, 2026
