Kayteg1
Mar 02, 2016Explorer II
With the additional explanation this confirms my first guess that break was result of improper technique.
Grade 8 bolts should not be welded unless proper warming up technique is applied.
Wrong design to start and looks like Winnebago does not have good fix for it.
I would tend to agree with other suggestion to just put additional nut without a weld, but hard to say if the space could be an issue.
Welded high-tension bolts are not easy to cut with blade and not easy to drill.
Grinder might be only good tool, but than you need good access and protection from sparks.
38,780 PostsLatest Activity: Jul 04, 2015
