Vegas1ExplorerFeb 29, 2016FWS Major Failure (see photos) *UPDATE*Today I noticed the outside end cap to the Power Gear ram was getting hung up when retracting the full wall slide. Upon closer examination, it was discovered that two bolts that secure the floor to th...Show More
427435ExplorerMar 02, 2016Bad design to put a bolt in bending. They should only be used for clamp loading (bolt in tension) unless the load is very minimal.
Related ContentHitch Failure UPDATETire Failure-Update IV8531 /Burner Issue UPDATE--Photos ( Fixed!)No Warning Tire Failures UPDATEStory behind F450 pickup frame failure? (photo)
