phillyg
Apr 28, 2013Explorer II
Artum Snowbird wrote:
Just be careful with the undercounter footprint... I did a replacement and ended up having to cut away quite a bit of the plywood underneath to get their holddown rings to fit.
X2. If the existing fittings are the same as a common household faucet, then any one will do. For the plywood, I usually pull out one of the most versatile tools from my kitbag, the Dremel tool with a woodcutting bit.
