msmith1199
Mar 24, 2016Explorer II
Here's the roof. Note the sat dish right up against the seam and the antenna on the other side of the seam in the front cap.
This is the inside of that view behind my TV. The right side of the photo is toward the front of the TV. You can see the antenna coax coming through the hole and you may be able to see a screw from the satellite dish behind that right near that gray conduit. You can see a steel cross member out in front of the antenna and a steel longitudinal member over at the far end. So the seem is just running over the top of this wood. It's actually not even plywood but some type of particle board. But it is 3/4 inch thick. So I want to get the screws down through that like they are for the satellite dish.
