Gjac
Mar 28, 2016Explorer III
lafrentz wrote:My 96 GBM is cap is woven FG I am assuming the op's newer MH is the same. You can look inside the upper cabinets and tell for sure. Either way if it is just chopped fiber, which has a lot less strength than woven as long as the resin to fiber ratio is the same which is usually 60% fiber to 40% resin(assuming an isotropic lay up) the CTEs will be the same. Also once the roof and cap are mechanically fastened you essentially have a one piece roof anyway unless you create a slip plane with over size holes. I agree with lafrentz you don't want to turn this into a WPA project.msmith1199 wrote:wildmanbaker wrote:
OK. A lot of ideas, some good, some not so good. I believe that you cannot make the roof and front cap all one peace because they are made different. The front is probably chopper stranded lay-up and the roof is fiberglass pad lay-up, and will not expand at the same rates. If it were me, I would through bolt the parts together, fit a thin peace of aluminum to comer the seam, then use the sealing method of you choice to cover the seams on each side for peace of mine. This was any differences in expansion, is covered by the cover strip, and there is no open, so to speak, to leak. Just my opinion, and everyone knows what ones opinion is worth.
And if I could do that I would, but as I explained I can only access the underside of the roof for about three feet in the middle. That leaves about 3 feet of seam on either side that I can't get to because the ceiling is in the way. Removing the ceiling would require disassembly of the entire front end which means pulling down cabinets and the TV and the covering on the ceiling, etc.
when the tiffin repair people change out 40 foot fibreglass roof radius units they use high grade "pop rivets" and seikoflex bonding adhesive.Glue two pieces together with that stuff and its never coming apart
