Does anyone carry a spare gas can when on long trips? Carry it where? Full or empty. Still debating on taking the EU2000 on road trip, even if the built in works fine. Things to consider, DW ran the r...
You're overthinking. Unless you need to run a generator all day for some reason, then you might enjoy having the Honda along. In which case you'll need a gas can.
But for normal uses, no way. Use the Onan, fill up your fuel tank when needed, and forget it.
